I'm putting dome's over some 575 spots to use outdoors and assume I need to install some fans to pull heat out. Any thoughts on if I need to have air moving up in the dome or is pulling air across the base enough to keep it cool? I'm assuming I need air primarily in the dome to cool the lamp...
