Are you concerned about the angle of the projector or actual fixture? I think this is what he wants. HES say not to hang a DL.3 on a strange angle.. could be the same thing..?
Thank you for your help. Thank you Marty. just Fixture issue I want to hung by 2-doughty cramp. I want to know, is this possible or impossbible? Thanks, Toshi
Please see the excerpt from the DML-1200 User Guide below. You can use the corner points, but it is recommended that you use 4 hang points.
"Rigging points and rigging clamps
Four slots are longitudinally (A) oriented and four slots are transversely (B) oriented. Each slot contains a rigging point of which the position in the slot can be adjusted depending on the size of the truss installation. The rigging clamps (C) can be attached to those rigging points, which allows an easy and fast physical setup of the device in a hanging configuration. The 4 corners contains also each a rigging point as well as 2 fixed positions in the middle of two sides.
Warning: Always use four (4) rigging points, equally spread, to suspend the device."
