What is the actual lens ratio for the dmls? I've seen the degree range on the Barco literature and a range of 1.3:1-4.4:1 on another site but that 1.3 doesn't seem correct based on my experience with them. Seems closer to 1.5ish. An official answer would make my blend math easier.
Hi Dave, You are quite right, its due to Unfocused and Focused range.
The official lens ratio is: Focus1.45:1 - 4.64:1 Unfocus 1.35:1 - 5.2:1 Also see the Image Size Chart. www.barco.com/projection_systems/downloads/DML1200ImageSizeChart.pdf
