That message means that the Axon cannot find it's hard drive. If you have any USB devices plugged into the Axon (flash drives, etc) please remove them and also check the hard drive connections on the drive itself and the motherboard. Then try rebooting the server.
Urgent! Want to ask that have the fan outlet A low message. If the fan didn't rotate when check it. Is it possible for the fan error or the PCB for the fan? And what is the voltage for the fan? Thanks a lot.
I believe this error is specific to one of the fans on the Power Box This is in the head of the fixture, the main power box where the fan control board is located. (the one with all the connections)
This error comes from one of the following: Disconnected wire Blocked fan Damaged wire Fan end of life Error on fan control board
