HI is there news for artnet in new version If we have to use artnet with start 2. And to work with CMA and consol connected in artnet Is it possible now Could we change server
Excuse my language We can't use cma and DL2 when it used artnet protocol Arntnet used IP start 2 and ip server is not the same SO how to connect the both
Using Art-Net and CMA at the same time is possible, but it depends on your setup. If you are using an Art-Net box from Artistic License, these can be custom configured to work on a 169.x.x.x network, which is the same address that the DL-2s default to.
If you are using an Art-Net source that cannot be configured, it is possible to use a network router to assign your DL-2s a 2.x.x.x address, which will make them work with Art-Net, and you can plug your CMA in to the same router. However, there is currently a known issue that if you use a router with no internet connection it causes issues with the CMA. This will hopefully be fixed in the near future.
