collage access.
Your instructions posted on the websight talk about GLobal modifier 1 needing to be at a DMX value of 134 to access the collage function. Then says Modifier 1 at a value of 1 to set up the configuration I am using.
The language your using on the websight doesn't compute to what my Hog II PC stage output says.
Can you put the instructions in the form relating to what the output parameters say on them. Otherwise I am going in circles and getting knowhere.
The parameters on the global section are as follows:
cyan/magenta/yellow/Fx1/Fx2/Fx2m1/Fx2m2/Fx2m3/masksel/masksize/
maskfade/fadetop/faderght/fadebot/fadeleft/keyx1/keyy1/keyx2/keyy2/
keyx3/keyy3/keyx4/keyy4/keyxrat/keyyrat/viewmode/viewxpos/viewypos/
viewzpos/ctrlmode/ctrlvalu/
I need to know if Fx2m1 is modifier 1 ect...
Do you have any conversion charts that convert the language for us lighting /non video guys?
