Cross focusing units for larger veiwing fields and collage
Ok, Here's part 2. I've only got about 12' of throw distance from the units to the projection surface. And of course, budget is a issue. I have only seen the collage effect work if the units are relatively focused straight in at a 90º angle from the unit to the projection surface. Is it possible to cross focus the units to make the fields larger and correcting the keystoning (which one has to do when using collage) thus using fewer units to fill in the space?
I understand the percieved brightness of the units will diminish from one side of the projection field to the other. My question is will collage work in this scenario?
I am assuming that it would as long as I tell which unit goes where in the collage set-up window. Any takers for answering this "riddle me this?"
Jay
JGLD, Inc
