DL.2 v1.3.2 Released!
We have just released verion 1.3.2 of the DL.2 Software today.
This version adds a number of new effects and improvements to the software.
The Press Release for information about new features in this software are located at: www.highend.com/news_events/news/news_detail.asp?news_id=379
The full Release Notes and Software are available at: www.highend.com/support/digital_lighting/DL2andAxonSoftwareUpgrades.asp
Parents
  • [quote=Marty Postma]Hey Keith are you talking about a DL.2 or an iPC?? I've never seen a DL.2 with a 90-deg adapter for the graphics card:confused:. The iPCs all have them though.
    I think Keith might be referring to the VIVO connector ;) If that connector is even the slightest bit loose it can cause the menu not to show up. Chances are, by removing the computer and reseating this connector when you put everything back in it fixed the problem.
    One thing you can do to make the connection a little tighter (before going all the way to glue) is mis-shape the outside of the connector a little bit. I normally just take a needle nose pliers, grab the rim of the connector and give it a little tweak. This will make it fit tighter in the socket and be less likely to get loose.
Reply
Children
No Data
