Aah. That's interesting. I'm surprised anything would be drawn before all of the layer options (like scale) had been calculated and applied. Do you not see the problem when the scale is set at 1x?
With this additional information, it sounds like this is a Catalyst problem. You may want to get in touch with support or post this on the forums at the www.catvx.com web site.
[quote=teerickson] I'm surprised anything would be drawn before all of the layer options (like scale) had been calculated and applied. Do you not see the problem when the scale is set at 1x?
Oh believe me Tom, I bug Richard litterally 5 to 10 times more than I bug you. That's part of the reason Catalyst now uses TripleHead2Go and DualHead2Go devices now.
It's not so much what I would call an issue, more like trying to squeeze the last 1/2% out of something.
