DL3 collage and sdi input.
I am currently running (6) DL3's in a 3x2 enhanced collage. I am also using the SDI input to the fixture to map a feed from our video rig through the collage. Most of the time all is fine and dandy, but after about 20-25 minutes of ingest the DL's lose sync with each other. It starts out small (1-3 frames) then gets further and further off (give or take 2-3 sec.). The stock content seems to stay mostly in sync during all of this, as we switch from DL content to the SDI input. The only thing that seems to "re-sync" them is a reboot from CMA. So I was wondering if anyone had any ideas as to how to correct this.
All of the DL's are running v1.3.7.1382. I was wondering if this may be addressed in v1.4.0.1699. Just haven't been able to drop the truss yet to upload the update.
Parents
  • As far as signal flow/ sync. Fixtures (in order of cable patch) 1,3,5 stay in sync. 4 is staying close. 2,6 are way off. The faster the motion in the content the further off it gets. Slow motion/ steadier content seems to keep closer to sync. Hope that helps.
Reply
Children
No Data
