Collage Rotation
Hello Everyone,
I just want to make sure of something before I sell my client on an idea. I will have several DL3's placed around the floor of a room shooting the ceiling, and I want to use the collage function. I just want to make sure that I am able to rotate each fixtures image on the Z axis to create one seamless collage even though the units will be projecting from several different angles around the room. Hope I described this accurately enough.
Thanks.
  • This is entirely possible, but keep in mind that depending on your fixture locations/orientations you may loose large portions of the raster.
    You also may need to do some unusual collage grid assignments to get things to line up properly so that good collage "sampling" occurs (how the fixtures cut up the overall image into smaller ones to be collaged).
    In short it is do-able, but you will want to examine how your fixtures are placed very carefully to make life easier.
    Hope this helps.:)
