Urgent Dl.3 problem
Hi everyone, we are currently using 4 Dl.3 for the second time and now when I try to use CMA no dl.3 show up. We are running lastest cma version and dl3 version.
Another question, Cam the ethernet port "die"? I mean first time we used them we lost contact right on the show of 2 dl.3, never got ethernet to work back on them and they were Brand new, In the box.
Anthony
Parents
  • Actually they are not.
    There is a relay in the rear I/0 baord that switches between the singal coming OUT of the video card of the computer IN to that rear board via the DVI/VGA cable.
    The 5-wire BNC that you see connected are the wires that go to the projector. So when you select "External" the relay clicks over and bypasses the computer's signal.
    The VGA and 5-wire connections on the outside of the fixture are actually hard-wired (soldered really) into the same "circuit" on the PCB....they are NOT the wires that you see connected to the I/O board in the harness.
    Hope this helps.:)
Reply
    Hope this helps.:)
Children
No Data
