d.l.3 video inputs
hello! so this is my question, witch
video inputs of d.l.3 are going through the
graphic engine ? and what's the use of SDI input, output?
and if u could explain all of the video inputs, outputs
U have the best customer support!
thanks!
  • Hi Marko,
    Both the SDI and s-Video are considered internal inputs since they go thru the media server.
    The RGBHV and the VGA are considered external inputs, as they feed directly to the projector.
    The general idea behind having both an SDI IN and OUT are so that you can take a signal in from, lets say the DL.3s camera, and send that feed to other fixtures. In other words, you can essentially daisy chain DL.3 together with SDI.
    Hope this helps,:friday:
    p
  • The THEORY of daisy chaining SDI is sound...but in practice there are some as of yet unresolved issues with DL.3. See this thread:
    forums.highend.com/showthread.php?t=5818
