DL2 Collage custom content
Can someone confirm that these settings are correct when creating content for collage generator in a DL-2 fixture excluding standard foot age size.
3 x 1 array which i have asked the content makers to use a resolution of 1648 x 472 ?? So far the test content is freezing the DL-2 heads and stopping the servers totally.
Any quick feedback appreciated.
Can someone from HE post a telephone number of DL-2 support in europe please.
Thanks Cormac
Standard Footage Size
640 x 480 pixels, 4:3 aspect ratio
Bit rate per sec, bps
(Visual Quality Setting)
Constant Bit Rate (CBR) 10,000,000 bps -12,000,000 bps
Frames Per Second, fps
24 fps, 25 fps or 29.97 or 30 fps (Set Encoder fps accordingly)
Group Of Pictures, GOP
GOP Structure should be All "I" Frames
Video Stream Type
Elementary Stream (Warning: DO NOT use a Program Stream that may have audio)
Progressive Output The footage should be encoded as a progressive frame file, not an interlaced file Color Space4:2:0 (Warning: DO NOT encode to 4:2:2 or other color spaces)
