DL3 iris
having a bit of an issue with a DL3 iris which does not seem to calibrate correctly.
I have watched the fixture power up and the encoder seems to count the teeth and then set the iris accordingly which is not happening correctly at the moment.
Any ideas on what could be causing this and what if anything i can do to fix this,it is not an everytime thing but just randomly happening.
Regards C
