Realized something curious today. The lamp hours indicator in the CMA appears to top out at 1666 lamp hours. Our system has 6 DL3s and I needed to replace a blown bulb last Saturday evening. I noted the lamp hours on all the fixtures at that point and the fixture I replaced was at 1666 and the 3 other fixtures that still have the original bulbs were also at 1666 lamp hours. I checked the hours again today and the "new" bulb was at 50 lamp hours, the two other fixtures that have newer bulbs in them had incremented 50 lamp hours, but the 3 fixtures that were at 1666 lamp hours last Saturday, are still at 1666 lamp hours - and yes, I'm sure they were also lit and running with the other units between then and now.
Anybody else run across this?
BTW: DL3's and Hog = One of the best systems I've ever run/owned/operated!!:You_Rock_Emoticon:
