DL2 Problem with pan cue
I have a problem I need help with. I am using two DL2 and the D-Pro software. I have written 3 cues that are all the same except 1 and 3 have the intensity out and 2 the intensity is at full. All of the other attributes are the same and do not change (my color, the rotation, the media, etc) My problem is the light is not coming up instead the head pans in every cue as if it is trying to go to the position but realizes it is already there. What would cause this problem? The dmx output says the only thing that is moving is the intensity and the patch is correct. I am at a lost.
Thank you,
Johanna
