bnjie, The BIOS battery in located on the motherboard of the server. It's about the size of a quarter. After replacing it you will need to load the default BIOS settings by following these steps: Connect a USB Keyboard to the fixture Power ON the Fixture When the media server is turned ON, repeatedly press the ‘DEL’ or ‘DELETE’ button on the USB Keyboard. This will open the BIOS Settings. Using the Arrow Keys, go to the ‘Save and Exit’ Menu Option at the top. Go to the ‘Load Default’ and press ENTER. Confirm. Go to Save and Exit. Confirm again.
Thank you for reply, but where is the motherboard located on the fixture. I have opened the sides on the base of the fixture and can´t locate motherboard, do i have to open it in the bottom ?
Follow these instructions: support.etcconnect.com/HES/Digital_Lights_and_Media_Servers/Digital_Lights/Replace_BIOS_Battery_in_DL2%2C_DL3%2C_DLV%2C_DLHD
If you need more help it would be best to email me directly at chris.litz@highend.com
