Does the CMA program work on Windows 10 at all?
If not, what is the best way to connect to these lights? Would a VM work or would a dedicated XP/Vista/7 computer be required?
Thanks for any help you guys can give.
I know this is an old thread, but you will need to enabled SMB V1 in Windows 10 /11 in order to access the units with the CMA. Also make sure you run the program as Administrator. As an alternate, we use an older Windows 7 Laptop that is dedicated to the CMA software.
