How hot does a source 4 leko get at the connection with the lamp base?
Check out this wiki entry:
which says:
S4/S4 Zoom/750w
Lamp Focus Knob: 210°C (410°F) max.
Exterior Rear Housing Skin: 217°C (423°F) max.
Of course, this will vary depending on lamp wattage and if the luminaire is incandescent or LED.
-Todd
Hot enough that you are not going to solder the leads to the contacts......if that is what you were thinking.
It is an easy fix to replace the socket, and unless it is an older casting (pre '96 ??) you can use an one-piece socket....if that is why you are interested
