Colorsource Spot staying on and cannot change use interface
Hello,
I am using multiple new colorsource Spot's and I have run into some issues. One of my fixtures does not react when I press any of the buttons [Mode], [Up], or [Down]. The only thing the displays shows is 001, which is its address. I tried unplugging and plugging it back in and I tried to reset the fixture but nothing works. Any ideas on what is wrong and how to fix it?
A second problem I have is that one of the fixtures stays on when I turn the fixture to 0 intensity with the console. When I flip through the DMX address's on the fixture I end up changing the colors through an RGB cycle, currently the address I am using is 440 and it stays on red.
Also all of the fixtures are running v1.6.0
Thanks in advance for the help,
Rembrandt P.
  • Hallo,
    Sounds like fun, I think it would be best if you contacted your local Technical service folks.
    For technical support in the Americas,
    please call 608-831-4116
    or toll-free in the U.S. at 800-688-4116
    service@etcconnect.com
    For technical support in Europe, The Middle East & Africa
    please call (+44) (0) 208 753 0984
    techservltd@etcconnect.com
    For technical support in Germany, Austria, Switzerland, Eastern Europe & Russia
    please call (+49) 8024 4700-0
    techserv-hoki@etcconnect.com
    For technical support in Asia,
    please call (+852) 2799 1220
    techservasia@etcconnect.com
    Cheers
    Chris
