On may of the motion picture projects that I have worked on recently I have seen an increase in S4 fixtures geing used in the Gaffer's arsenal. I am curious to know if ETC has ever looked into making a some options for the S4 (par and leko) that will make is more 'film' friendly. If shops chould get the fixture form the factory with a 1 1/8" (sinior) pin on it rather then a standard C-clam that would be a step in the right direction. The ability to get the fixtures with a longer tale made of SO (or similar cord set used on film heads) with a switch in-line, would be amaxing. And if there could be a set of scrims made for the fixtures tha would also be great. And possibly an insert fo the color frame slot that would provide better attachment of color with C-47's. Now that would be hot.
I know that all of these things can be piecemealed together, but if they were available form the company tha would be amazing for us gys and galls that use a lot of S4 for motion picture work.
