I have a very big, urgent request.
In the current firmware, there appears to be an internal threshold in the Series 3 fixture that is between 23 and 24 percent (intensity). This means that if the threshold of 24 percent is not exceeded and the intensity is switched off in 0 seconds, the black out is not cut, but the spotlight dims itself. Regardless of which dimmer curve you use.
This is not a nice behavior, because that's what the self-selectable dimmer curves are for. Hence my request for a quick correction via firmware update.
In the meantime, of course, I have my workarounds, but they shouldn't be a standard solution because it makes programming unnecessarily more complex.
Thanks very much!
