Hello,
Has anybody tried to run signal from City Theatricals MvTx(firmware 2.0.0.9.0.322)to more then 5 fixtures? The data sheet says it can do 10 universes, from what I read it should take much more then just 5 fixtures. My client who bought MvTx and 10 x CS wireless relays noticed that transmitter drops randomly some relays. I ran my own tests and I tested it literally with all possible settings, you name it, I've done it. It cant keep more then 5 fixtures connected. And it's not the relays, because if to switch the power on relay, nothing happens. If You switch the power on transmitter all receivers wake up until some of them are lost again. And it's not only about the relays. I have had many projects lately that include MvTx. And all my MvTx clients have told me they cant work with it. It's just not reliable enough. It has been now 3 months now since I wrote about this first time, unfortunately nothing has been done to fix the fault. Clients are really restless already and asking to buy those transmitters back.
