At first this may seem like obvious questions, but please hang with me on this.
1. What is the max pixel resolution of the AXON output? I.e. Can it drive higher resolution projectors than the 1024 x 768 that is on-board the DL.2? I realize in the DL.2 that res level is set to match the on-bard projectors, but with the AXON it would appear that the only limit would be what the graphics card/processor could push? So in theory you could conceivably go higher in the AXON depending on the complexity of your media/layers/FX.
2. Is there anyway to feed a 16:9 proejctor with an Axon or is it only 4:3 output?
Thanks for your help.
