does anybody have the exact settings to make a custom mask using photoshop or similar,client has a custom front projection screen and is going to make a mask so the image is only visible in the middle and does not spill off the screen,was going to adjust the size within axon or is that not correct?
Has anybody had seen light output loss on the other layers that will have the media playing using this method...i was thinking that that there might be some loss of output?
Will the global layer of axon still be able to make the layer mask a soft edge or should that be part of the actual image...not sure as i dont want a hard edge.
Thanks Cormac
