What is the local drive? Are you using a USB stick? Exernal HDD?
Are you plugging into the front USB ports of the AXON or the rear USB ports?
I've seen a few cases where the wiring harness to the front ports has been knocked loose in transit and had to plug only into the rear ports till the problem could be solved.
Are you by any chance plugging this USB into an Apple/Mac computer? sometimes it will dump stuff on there without telling you that renders the stick unreadable to PCs.....
