SDI Output
What we are trying to do is output media from the Axon via the SDI out to a PC running Arkaos Mediamaster with a SDI capture card. The Arkaos is purly there for pixel mapping purposes.
We have done this before using a composite capture card and the dvi out from the Axon passing the signal thru a extron converter.
The question is will the axon output SDI video?
cheers
