The SMB Access to the mediaserver is controlled by username: Administrator and a password. Since this product is not maintained any longer can you share the credentials. This would help a lot, since the CMA application is hard to use
I do not think this will be possible due to the proprietary communication between Axon and the CMA.
Would you consider to share this information, as the product is not supported any longer.
Or do you have an API to CMA that could be used?
/Fredrik
I'm sorry, but we will not be able to share. I suggest using the latest CMA.
OK, thanks.
Is there any API to CMA so I can have an external application accessing it, e.g. Upload File X to Folder Y
/Fredrik
I'm sorry, but CMA is the only app that we have for this.
Yes, that is crystal clear.
But my question is if the CMA application provide an interface/API so I can access it from another application
/Fredrik
CMA is a standalone app.
