it will play a movie that has audio. movie must also have a video track. audio only files are not supported.
audio in movie needs to be uncompressed aif format, not mp3.
if you playback audio - you need to change the way you work - audio takes priority ( audio must not glitch... )- and you cannot play really playback other layers without audio very well at the same time.
