chaldee1.gotadsl.co.uk/~richardb/upload/showthread.php?t=897
Greater mix flexibility:
Global keystoning on mix and sub-mix outputs.
Support for Matrox ‘Triple Head 2 Go’ for 3 ‘full screen outputs’, or 2 'full screen' outputs from a mac mini or macbook using a 'Dual head 2 Go'
Picture in Picture mixes. Multiple mixes on screen with no HUD visible.
Preliminary left right top bottom edge blending on keystoned mixes with 10% 20% and 25% overlap
Left right panoramas and Up down panoramas.
Edge blending curve editor.
Mixes can be offset and joined together allowing panoramas.
Editable edge blending percentage, and editable mix offsets.
Much improved sync between layers on local and remote playback layers.
New ability to lock to exact monitor refresh rate.
Fixed artnet universe output mapping incorrectly restricted.
Added MMC ( midi machine control ) device.
Added Leitch video switcher device- uses 16 dmx channels to control the sources and destinations on a Leitch switcher.
Ability to select mix layers from DMX
Tiger compatibility only ( OSX 10.4.6 minimum )
Universal Binary. Intel and PowerPC ( G5 )
