ledwall, DLP projectors and Hog III
hi, I will start to work with a ledwall and a DLP projector system that will sobsitute a 8 DLP projector system based on Watchout technology. Now I would like to program lights and video with an Hog III and a Catalyst media server system and everything must run with an LTC timecode. It is possible to control ledwall (video and lights) and a DLP video source with an Hog III or I must program my show with an hibryd system using Hog III for light and ledwall and watchout for DLP source and ledwall with video?
please help me!!!
tanks a lot
  • Paco,
    You can use Whole Hog and Catalyst to achieve what you are talking about. Catalyst has two outputs as well as PixelMad. This allows you to send video to your DLP projector and map to LED devices via ArtNet. The Whole Hog does accept LTC but you will need to get an IOP. Please give us a call if you need help planning out this system. Thanks!
  • Hi Zach,thank you for help. when I was looking for help I was downloading catalyst 4.0 manual and I was starting to study. I only use Hog III since 2003, but it will be my first time that I'll use with video, because I'm also a Watchout programmer, and I've always used that system with video. Now I would program lights and videos inside an important musical with just a source, and catalyst is the only way.
    I think I'll have no troubleshoots, but in case of them I'll give you a call.
    thanks again
    paco toscano
  • Hi Paco.
    I can give you all information you need about use Catalyst
    servers on PixelMad or DLP projector together HogIII.
    No problem at all to use time code.:friday:
    Many new features on last Cat v4 software version permit
    different configuration from PixelMad,DLP Projector,or both
    together, up to 8 output each computer.
    I will contact you very soon.:phone:
    Bye my friend
    :hogsign:III LOVERS.
    ROBERTO NOVELLI
    PRODUCT MANAGER Resp. Tech. Dept.
    Ianiro Aldo srl Company
    roberto_novelli@ianiro.com
    ianiro_lab@ianiro.com
    www.ianiro.com
    tel.+39.06.93.10.198
    fax+39.06.93.162.162
  • Roberto,
    Everything OK
    To correct you a little, Catalyst V4 can have up to 6 Outputs (using 2 trippleheads To Go from Matrox.)
    And you can have 8 Inputs.
    KEEP ON :hogsign:GING!!
  • Hi Big Frank.:D
    Last soft CatV4_m132_UB-HD
    Support:
    4096 x 2048 image size (for sure)
    4096 x 4096 image size (not sure)
    14 Layers
    8 Sub Mixes
    8 Video input with many new input effect settable on HUD like:
    interlace on/off each video input
    color Fx each video input
    Fx possible crop image each video input
    possible copy input (good when you use a single input video card).
    This option are possible on HUD only and is good to have free the
    Fx and color Fx parameters on consolle to do different effect
    on the Layers.
    And many others good features.
    bye
    ROBERTO NOVELLI
    www.ianiro.com
  • Hi chers. i forget details.
    There is different way to have 8 video output SVGA/DVI on
    the same MAC PRO.
    But you need to use different external interface
    from Matrox TripleHead2go.
    bye
    ROBERTO NOVELLI
    www.ianiro.com
