Hi.. I am having pretty lame problem with catalyst and I think problem is in content like I play 10 videos on catalyst and when 5th video starts it simply drop out and catalyst software turns off.. its pretty much same as DL.3 when content is wrong DL.3 simply die but here just kick out of soft.. so I would like to know is there any way to check are there any prblems with MOV files or that could be problem with Self catalyst soft???
It sounds like you are overloading the software....many older versions of Catalyst will not support more than 4 simultaneous video streams at any given time. Not every layer can necessarily be a running video stream.
What version Catalyst software are you running? What is the hardware spec of the MAC it is running on?
What type of drive do you use for content?? SSD or SCSI? When was the last time your content drive was zeroed? What version OS-X are you running? Leopard? Tiger?
