4.2
i don't seem to be able to easily see the type of gateway in spreadsheet view. in a heterogeneous system it would help a lot to see if a gateway is an original Net3, a Response or a Mk2 gateway.
thank you
ueli
4.2
thank you
ueli
The Net3 and original Response gateways run the same software and don't distinguish between the two types, but the Response Mk2 version numbers restarted at version 1.1.1 so in the meantime, you could look at the version column to determine if the device is a Mk2 or not.
thank you. that's the method i've been using, but it's not very intuitive and also requires more knowledge than i think should be required to find such a simple piece of information. not even the properties editor seems to clearly tell you the device type. you have to go by the symbol in the worldview and then start guessing if blue or magenta gradient were the Net3 or the Response model.
