The theater I work at is looking to buy a new board. I've convinced them to get an Ion, which is a major upgrade to the current Colortran Innovator. I've used the Ion plenty, but I've never had to deal with the networking part of it, so I'm not too familiar with that. I want to make sure the Ion will do what we need, and make sure we get any additional routers or gateways or ethernet switches necessary.
Like I said, we currently have a Colortran Innovator. It has 3 DMX outputs that run to three DMX ports in our booth. One goes directly to the dimmers (some type of Strand dimmers, not sure what exactly), the other two go to DMX ports in the FOH cove and over stage. We currently have about 150 dimmers, 4 moving lights and 5 scrollers. We don't have enough addresses to eat up an entire universe, but it's been pretty great having dimmers on one universe, movers on another, and scrollers on the third; it's much less cable to worry about.
Since an Ion only has 2 DMX outputs, we would definitely need a Net3 Gateway to connect to our third. But I'm not looking to just buy what we need to make our system work right now, I want to do a little upgrade to the infrastructure to make things easier for us in the future. I have an idea, but I'm not actually sure how the Ion works over an ethernet network. Is it as simple as an Ethernet switch connected to the board, any gateways, and any potential future backstage ethernet ports? Would we need any specific ETC Net3 ethernet hardware?
I'm thinking we can get a 4-port gateway and an ethernet switch. Plug the gateway and the Ion (routed through a wireless router) into the ethernet switch, and then assign three ports on the gateway to output to three universes and leave the fourth output open for future expansion*. If we have this setup, would it allow us to eventually install additional ethernet ports backstage, connected to this switch, and plug in more DMX gateways?
*Could we also configure the fourth DMX port to be an input, so we could run DMX from the board to the gateway and run things that way? Would that limit us to just one universe? I'm just curious about this part, I don't see a reason we would need to do this unless something went terribly wrong with an ethernet port somewhere.
Thanks for the help.
