Have a Gio with Ion as backup on a Network with a Net3 gateway to output two universes of DMX.
We have bought some inexpensive LED battens for an upcoming show, and when connected via the gateway there is a noticeable drop out of level on the LEDs every few seconds. I connected directly to the Gio's DMX output and no such problem. I then connected directly to the Gateway (in case it was a building/cable issue) and the flickering out happened again.
Any suggestions on what the issue could be?
