0-10V Dimming to DMX 512
Horticultural Lighting.
First, let me say I have very limited understanding of DMX controls and equipment.  I'm involved in a project where DLI lighting sensors are being used by the building controls contractor to accumulate ambient and artificial light.  The controls contractor can only output 0-10V and not DMX.  There are approximately (8) 0-10V outputs (zones).  There are approximately (100) lighting fixtures that need to be DMX controlled for the obvious flexibility of adjusting light levels and reassigning to different zones.  The ETC site is massive and my knowledge is low.  Can someone point me in the right direction?
Thank You
  • Hi there, I would recommend, an architectural controller such as Unison Mosaic. Mosaic would be able to take a 0-10V signal in and use it as a trigger to alter DMX lights. If you'd like some system design assistance please get in touch with your local representative. A list of representatives can be found here: http://www.etcconnect.com/Contact/Americas.aspx
    -Lowell
