Net 3 Concert
Hi all,
Is it possible to print out the configuration for a Sensor Rack via Concert. I tried the export function in the rack edit window, but all I get is an sort of empty xmml file.
If this is not possible, could this post be counted as a feature request....
  • Hello Flo,
    The "export device config" option produces an XML file that can be loaded on the CEM via the USB port.
    If you want to export the data in human readable format, this can be done by double clicking on the Sensor 3 rack can clicking on the "Export ODS file"
    This creates an open document formatted file that can be edited and re-imported, or printed.
    Regards,
    Marcus
