O.K So brief run-down of the system.
1 x ETC EOS Classic 2.4.0 (only console on the system)
On Stage RACK.
1 x Unmanaged 10/100 switch
2 x NET3 4 Port Node
1 x Show Control Gate way
---- from this rack on stage, we run a 90m Ethercon snake to FOH Control to another smaller rack which includes
1 x Unmanaged 10/100 Switch
1 x NET3 4 Port Node
The EOS connects to this switch.
During technical rehearsals, we ran another cable from this switch to the EOS which was in the stalls. We were getting massive lag issues sometimes up to 7-8 seconds worth. We ran a separate Cat5 from the stage rack to the desk as it was closer and it seemed to solve the problem and thought it was length of cable.
Move the desk into control box for first preview and plug back directly into the switch on the FOH rack so only 90m Snake and a 2m CAT5 from the switch to the EOS. Again, massive lag back during the preview.
Again we think the snake is longer than it says it is and luckily video are using a 75m snake so were used a spare connection on that snake and took ours out of the system. The lag disappeared and all seems to be fine. Show reports start coming in after I leave and lag is coming back every now and then and now out of ideas!!
Any help of thoughts would be appreciated.
John
