So I was commissioning a system, where I had to plug in and test the new 2port Net3 gateways one at a time, and manually set a static IP for each one.
Net3 Concert did a great job with the find unreachable devices function, and progressing through that dialog, getting to where I enter a manual IP and reboot the gateway.
Where it falls down for me is I was using a different IP schema than the default manual address it goes to of 10.101.50.61. I would like a place to enter in my own manual address, and have the program then remember that and increment it as I add devices to the config one at a time.
I don't feel the need for a full DHCP server, but in a system commissioning where there is no console as part of the package, Net3 Concert is what I use to configure the gateways, and if there were a place in the Options>Preferences to set that manual address, that would be very helpful.
