Net3 Network Latency Issues
Hi There:
Periodically I'm having a really bad network delay in one of the two Net3 Gateways we have on the lighting network.  I don't think that the gateway itself is the problem, I'd just like to see if my thought process on the situation isn't missing anything.  The gateway is outputting everything correctly, just with a 5-10 second delay from the desk.  It's also the entire gateway, not any specific ports.  It isn't snapping its output to where it should be; cues and manual commands are running in the correct time, just with the delay.  Because of this I don't think that there's a network connectivity issue or a bad cable somewhere.
Because I don't think the gateway or any cables are to blame I think that the issue is the brand of switches the company is using.  They're these plastic TP-Link things, and although they're gigabit switches, they don't strike me as switches of the highest quality.  They seem to be the point of failure, so I would hope that replacing them with something a little beefier (I'm a fan of Netgear's switches) would fix the issue.
Is there anything that I could be missing in this assessment?  Has anyone seen a delay like this in Net3 Gateways before?
