Reconfig Net3 gateway IP address.
Hi
I have a Congo Jr, Net3 2 port acn gateway and Laptop with Congo Nomad. I had gate outputting DMX and Nomad working fine as backup.
Connected Node to a Mac Nomad setup and tried to configure but without success. Then fiddle to get it working with Congo Jr including resetting dynamic ip address on node.
Now I can't get Node off the id address range 169.254. .
Used Concert and GCE. I can see Congo Jr and laptop under View Non-Configuarable ACN device. Can't see Node.
When Node is off network then powered on it searches ip then sits at 169.254.63.109.
What's can I do to get Congo Jr and Node speaking again?!
  • in concert, menu Options, there is a command "Find Unreachable Devices". can you find it there?
  • I left Concert - Find Unreachable Devices running on the Congo Jr for about 10 mins and it didn't pop up. It continued to search for devices. Is that long enough?
  • The 169.254.xxx.xxx address is the address that the gateway assigns itself when it doesn't receive an address from a DHCP server. That would be expected if the gateway was not connected to a network with an active DHCP server.
    Is the Congo Jr. acting as a DHCP server?
    Concert should still find the gateway, 10 minutes should be more than enough time.
    It sounds like there is a network issue somewhere. Can you give a description of your network setup?
