Concert - 4 Port Gateway - Update Server?
Hello,
Can someone clarify what the IP of the update server is for in concert?  Is this the IP that the gateway uses for "hold button 5 seconds to download software"? Or is it used for other things as well.   Seems to automagically change when I run updaterator, maybe I don't need to worry about it?
  • Hi ,
    You've hit the nail on the head. It is where the gateway will request software from when using the press and hold function from the face of the gateway. It does change to your computer/console when running UpdaterAtor as that is the last place it got code.
    If you are running a dedicated TFTP server or if you want to have your devices always ask a specific computer/console for software, you can specify it in the settings in Concert. Otherwise, if you are not using the press and hold update functionality, there is no need to worry about this setting.
