Concert 3 can't find a few things....
Okay, moving on to the next question of the day...
Why can't Net3 Concert find my dimmer racks and Paradigm controller. Attached is a map of the actual system layout; however all dimmer racks aren't able to be discovered. I can access their web-interfaces and login so I know they are locatable on this network and their IP's are the defaults.
Concert does locate all the gateways that are plugged in and the Ion console and Eos (grayed out because some are turned off at the moment), but even after running the "Unreachable Devices Wizard" the racks still don't come up. Have also tried switching Net2 to Net3.
