two questions:
- in AIP there seems to be a limit of 12 non-consecutive output addresses. when a range of output addresses there seems to be no limit. is this correct?
- is there a way of exporting the AIP from one gateway to another one?
thx, ueli
two questions:
thx, ueli
Hey Ueli,
What device are you seeing the limit of 12 appear?
There is a copy and paste for each port, if you select all, copy and paste...OR...there you can copy the entire gateway and copy then paste...
Net3 4port (not response 4port). don't know which concert version it was though, so maybe the limit was there?
The limit is specific to a single gateway can not output to more than 12 different universes.
The limit for each input address is 16 output addresses.
sorry for being daft, but how would i copy the AIP from one port to another port of the same gateway, or from a port of one gateway to another port or another gateway?
i see the copy button when editing, but it only copies the first address, even when multiple output cells are marked. Ctrl-C, -X, -V don't work...
Example:
Port 1, AIP edit window: click on any sACN Output Address Cell, then Cntrl+A, then use the Copy Button
Port 2, AIP edit window: click on any sACN Output Address Cell, then Cntrl+A, then use the Paste Button
duh, pasting doesn't just insert all, it only inserts into the marked cells. that was kinda unexpected...
