Hello ETC;
we now have a Response Analog IO Gateway (v1.0.0.10), and we can't seem to figure out what a few of the properties
in setup via Concert v3.1.0 do.
What are the parameters Analog Threshold and Rate for?
What is the Analog Port 1 INPUT Address Parameter for? It is set by default to 0,
where as for Port 2 it is set to 1. How does this differ from the Analog Port 1 sACN Address?
We are trying to measure voltage going into the input from 0-10v to create a way of measuring voltage in a system by sending
sACN values from the Gateway relative to the voltage inputted in, but it doesnt really seem to work well. We send 0.6v in,
and the display is showing 96%, then after 3 seconds, switches to 2%, and then back to 96%.
In the Analog IO Gateway Setup Guide, these parameters are not explained. We cannot find a manual for this product.
Do you know where we can get a more comprehensive manual than the current setup guide?
Thank-you
Robert
Scheinwurf - Munich, Germany
