Hello!
Will see if I understand this the right way:
When having a console with dual network ports it's recommended to run Net3 on one port and things like OSC on the other. But how do it work with switches? More specific unmanaged switches.
I know you can make separate LANs on managed switches but if I have a unmanaged switch is it still recommended and will it help to run double lines?
I made a fast paint picture to illustrate what I tried to say. Will this help over running all on the same IP range and network port?
The port 1 will then have the 10.101.x.x and port 2 192.168.x.x
