I really like the idea of all of the gateways now having a facepanel to confirm settings, and make changes right at the gateway. Really looking forward to that part.
However, I had a specific use case where I needed to install a single port in one of the DIN enclosures for a client that was using a mosaic system.
I really like the idea of getting one of the one port gateways with the RJ45 Jack, but now i need some method of mounting it in the ETC DIN enclosure.
Is there any chance ETC might make a Gang box that can be mounted to DIN rail, or any other kind of adapter for these boxes? I don't need any answer right away, but it was a thought that crossed my mind and I'd rather have a solution before when we get the check to buy parts.
What i personally would love, is some sort of 2 gang and 1 gang plate that can be mounted on DIN Rail to hold the gateway. Even sideways would be fine, but it still has to fit in the DIN Enclosure.
Thanks everyone!
