Hello Everyone.
I'm dealing with a system with the older Pathport nodes, running the "current" software of 4.3.2.
I seem to be having problems with configuring the Nodes through Concert, and was looking into some of the Pathport Software to do this.
Of course, there seems to be some sketchy networking problems in the system which could be masking the primary problem, so it may still work with Concert.
Has anyone else encountered anything strange like this before?
Do you know if the nodes are pathway branded or ETC branded?
If they look like this and say pathway on the front:
https://www.pathwayconnect.com/index.php/products/pathport-dmx-ethernet-nodes/57-c-series…
Concert will only configure ETC's Net3 networking products, so it's expected that it can't configure the Pathport nodes. Using the Pathport software is the way to go for configuring those products.
-Todd
https://www.pathwayconnect.com/index.php/products/pathport-dmx-ethernet-nodes/57-c-series-6201-6202-6203
You should download pathway's software for configuring them.
If they say ETC on the front, those are old ETC Net2 2ports, and you will need ETCNet2 Network Configuration Editor to set them up, which you can get here:
https://www.etcconnect.com/Support/Networking/Net-2/Software.aspx
Best I got is a sketchy photo of what Concert found. I still wasn't able to bring in the rest
