I have a new Response Mk2 two-port Gateway, I have it configured with an IP address that is in line with my other ETC items. I went into NET3 Concert to configure the network to see the Gateway, I added the gateway Icon to the network map configured the 2 port gateway with the IP address, subnet, and Gateway IP address. I cant get the network map to show that the Response MK2 2 port gateway is connected to my network. Any help would be great. thanks
Which version of concert, 4.0.2 ?
Wow! That's an oldie, John. The current version of Net3 Concert is 4.0.2 and that's the minimum required to configure Response Mk2 Gateways.
So I guess if I get the current version and install it I should be able to configure the gateway. My next question will the old net3 concert configuration I’m using now work on the new 4.0 net3 concert software?
I'm pretty sure you will be able to load a v1 config on version 4. I've never had problems with this previously, but have generally move 1>2, 2>3 etc. I expect you will be fine.
